Direct connection
Hi. Going to direct connect Kickr to my home network. Im assuming I’d be best to connect my Apple TV box to the network as well then hdmi to tv, rather than connect the TV to the network ? Hope that makes sense…
HDMI from Apple TV to the display. The Apple TV will also need to be on the network (Ethernet or WiFi).
You may still want to connect the TV to a network (Ethernet or WiFi) in case you ever want to stream to it from other devices or using the TV’s built-in apps, or to update the TV firmware, if that’s a thing for your TV.
