Direct Connection Issues [October 2025]
I’m no longer able to connect my V5 via dircon, so it would suggest it’s not linked to the V6 or their firmware.
It was definitely linked to the V6 firmware update. That’s when the problems for those users started, and when they released fixed firmware their problems disappeared. But that doesn’t mean you aren’t having a problem. It just wasn’t introduced by a Wahoo firmware release since the last firmware release for the V5 was more than two years ago. The cause must be something else for you.
I have had a few dropouts recently while using DirCon with my iPad.
This issue is far from resolved
The last few releases of Zwift, I have had slow initial DIRCON connection to my MacMini M2.
Zwift will attempt several tries before it connects.
Occasionally, it will move on automatically to the home screen, and I see it shows the number of connections in the top menu bar, but when you click on the icon, it shows No Signal as shown above.
It will eventually connect and show “Connected” without any intervention on my part.
I’m not sure if this is a MacOS issue or a Zwift issue.
I recently had my first DirCon (WiFi) issues in some time. I haven’t eliminated all possible causes, but I rode some warm-up with no issues, then started a race. In roughly the first minute / 500m, DirCon failed and power went to zero. I reconnected to the trainer using Bluetooth and finished the race fine, though nearly last.
Any other devices such as Click or a HRM? Which brand and model of trainer please. Were you connected via wired lan or wifi prior to the disconnect? If wired to the home network then wifi to a laptop mention that.
DirCon = Direct Connect = ethernet cable from the adapter at least to a router or switch on the same network as the device running Zwift. Possibly wifi from there to the device but consider ethernet for the least interference.
Dircon is not wifi.
Reason:
Tacx: both wifi and lan(aka ethernet or Dircon are via the dongle. Virtual Shifting can connect via Wifi/lan.
Elite: if equiped wifi is internal to the trainer. Lan (aka DirCon) is via the dongle. VS is currently (August 2026) only available with Resistance connected via Bluetooth.
Wahoo: wifi is internal. Lan is via Dircon dongle. VS can connect via wifi or lan.
Jetblack: (im not sure)
Were you using Virtual Shifting? Did Power disconnect or did Resistance fail which which would make it impossible to make many watts? Losing Resistance and spinning out has affected some users. A small wattage will still display if Resistance is lost.
I wonder if you could have reconnected via wifi or was Bluetooth the only working connection. As in was there a particular temporary problem with the wifi?
Have you used TrainerDX.com?
Robb, I’m the OP of the thread.
I currently have a Core 2, Core & Kickr v5, was using the Core 2 connected through DirCon over WiFi at this time. The PC I was running the game on was also over WiFi.
For your info, Kickr v5 can connect DirCon wired through the dongle (as I was doing when I started the thread), Kickr v6 can connect DirCon either over WiFi OR with a dongle, Core v2 can connect DirCon over WiFi ONLY.
I stopped using TrainerDX.com for log analysis when they went to their fee model.
Yes, I was using virtual shifting. Power disappeared, didn’t go to zero, came back briefly then was gone. I was streaming, you can look at it here on YouTube . The trainer showed “Connecting” in the pairing screen when I opened it. There weren’t any indications of internet connection dropping in the game - no disappearing riders, etc.
You still get 5 log reports per month for free, so it’s available if you feel like using it
Occasionally a really huge log file will use more than one token, but usually not
Looking at the Wahoo site I believe that DirCon is intended to refer to wired connection only. I often use wifi from my network to the laptop but do have it set up close enough that I sometimes use a wire. Dongle—>ethernet cable—>mesh wifi point with wired ports. Laptop—>ethernet cable—>same mesh point.
To me it appears the Core 2 does not support DirCon.
I used Dircon when I had a v5. I now have Dircon adapters for my Justo2 and Neo3m.
These connections still use Bluetooth packets but wrapped in TCP/IP for transport over the wire.
Wifi does the same TCP/IP wrap but routes over radio.
Click uses just the laptop Bluetooth radio to the best of my knowledge <–Yes according to Google see next post
(but I have seen a mention of a multicast mode that could imply both the laptop and trainer listen.)<-- cannot find anything else to support this
HRM can be laptop BT, Ant+ if equiped, or trainer BT then relayed in the trainer data stream which could be BT, wifi, or wired.
Bluetooth packets are the common thing being used for all transport methods. Only Dircon without a hop over wifi to a computer does much to reduce radio traffic and that assumes BT transmission stops if not used.
The link = " video unavailable".
Zwift treats these things as more or less the same.
It is true that there are a lot of reports about poor WiFi pairing experience with the Kickr Core 2. I don’t know if that’s the fault of the trainer or just that the trainer sold in high volume now has WiFi. It’s very common and the shortest way out is usually Bluetooth, unless the device running the game has sucky Bluetooth.
Yes, for this application it is all Bluetooth data packets regardless of how they get wrapped and transported to and from the device running Zwift.
The goal in the end is trouble free connection. The various manufacturers have chosen different routes. At one point I opened my Wahoo Dircon dongle and there was an unpopulated spot near the Bluetooth processor labelled ‘wifi’ yet when they built the wifi equiped trainers they put the wifi internal. Elite has done the same. Tacx has it the other way with wifi built into the dongle. These decisions could be as simple as expecting pushback from consumers if wifi was only available as a $130 add-on when $50 cameras come with built-in wifi. I don’t move the trainer much but not needing a dongle dangling to use wifi is nice.
I expect all of these are using 3rd party SoC hardware for Bluetooth as that is what makes sense. I forget the brand that Wahoo used but when I looked it up it was available with a developer kit as a drop-in solution. The SoC is also used for processing the data both directions and controlling the trainer hardware.
I see that some implementations seem more reliable than others. On my Justo2 I was getting mid ride resistance disconnects. At @Paul_Southworth 's prodding I revisited my laptop BT hardware and when I switched to a BT5.4 dongle instead of the built in BT4 radio and virtually all problems disappeared. I was a bit frustrated with Elite and had already been eyeing the Neo3m, which does support virtual shifting resistance over Dircon or wifi (but this requires the extra dongle purchase for either). So far with the Neo2 I have had stable connection over Dircon and am now experimenting with using the built-in BT for accessories again out of curiousity.
Given the different experiences people are having it is obvious not all implementations work equally. Hopefully we can determine how to determine where the problems occur and why.
Reading through again I suspect you had a connection drop but have 3-second power averaging on? That would explain the power dropping slowly.
Hopefully anyone with the disconnects is on the newer firmware.
Hmmm. This sounds familiar.
https://forums.zwift.com/t/bluetooth-improvements-for-controllable-trainers-treadmills-january-2022/569781/40
I think I see a problem. The very inclusion of “3) battery usage” in the text tells me there is misdirected focus. How many users are running off battery power, and what miniscule amount of energy would even be saved with a few less btLE packets? Reliability should be the focus. I don’t want the update to be “saved 1pWh (that is picowatthour) of energy” and only wasted 50,000 hours of peoples time trying to diagnose why it now randomly times out and disconnects. Is this why Zwift also does not transmit the speed and gives the trainer the task of trying to calculate it leading to the mismatches noticeable with virtual flywheel and speed based fan control?
Totally agree. It’s not just confusion - people will be wasting their time trying to figure out why the wired lan connection isn’t working.
