Difference between Jet Black Z1 and Z1 Pro
When using TrainerRoad you get to pick the Z1 or Z1 pro as your trainer, Zwift only gives you Z1. Is there any difference (other than the wheel locking mechanism) in the 2 and should zwift have both models there to choose from ?
G
We’ve only calculated the power curve for the Z1 pro, and I understand the regular Z1 has a different resistance unit. If you don’t have the Pro, however, you can still ride with a speed/cadence sensor using the “Not Listed” setting. :slight_smile:
Thanks Jason, maybe just updated the zwift client to call it Z1 Pro as all the other bike software available does, just to avoid the confusion ?
G
try to put a fixed resistance in the hand
