A Redditor is developing a new cycling app. Initially, it didn’t even support a separate power meter. I asked him to add that functionality, and literally one day later, my power meter and trainer connected instantly and correctly.
Meanwhile, every single time I launch Zwift, I still have to disconnect my power meter, pair my trainer as the power source, connect it as resistance, and then reconnect my power meter.
I’m absolutely fed up with this ridiculous workaround.
It’s 2026. Why can a single developer get this right in a day, while Zwift, with all its resources and years of development, still expects paying customers to jump through these hoops every single ride?
And instead of fixing it, Zwift keeps pointing users to instructions explaining how to work around its own shortcomings.
This shouldn’t require instructions. It should just work.
This is nice and all, but if two people use the same computer and trainer but with separate Zwift accounts and devices, we have to pair our Play controllers, heart rate monitors, and cadence sensors. Every time. When we switch bikes on the trainer we have to re-pair our individual devices, because Zwift remembers the last devices used period, not the last devices used on that account.
We switch users and bikes on the trainer probably 10 times a week. Why doesn’t it remember the devices by the Zwift account, not the last devices used? Makes no sense to me, and it is getting pretty old.
Why not make another user on the computer and do it that way?
Then you don’t have to log out and log in other users, and all of that info would be saved, and everything else like custom workouts, screenshots, etc wouldn’t be mixed.
That’s technically how it should be operated anyway; Zwift is designed for a single user, not multiple.
We do have two Zwift accounts. We log in separately to our own Zwift accounts using Zwift_Login. Why can’t it just remember our devices for each account?
Th new non-pairing screen is actually worse, because now we have to open the pairing screen. It used to open automatically.
But that is a pain for other reasons. Then I have to log-in to a different computer account. We pay Zwift for two accounts, why don’t they work as separate accounts?
I am hoping you might be able to provide some guidance on this topic of difficulty. Pairing trainers and bikes since the update. I have a couple of clubmates who have circled around with this on with customer support and are still having trouble, particularly during races.
The person with the most issues is on a Taxc Neo smart bike (v1).
Issues as follows:
"Windows 11:
Manual pairing. Disconnects from time of pairing to time of joining a ride. Will then not pair at all until I restart zwift.
Background pairing. Pairs but disconnects as soon as I pause pedaling e.g. on downhill or to simply ease. It does however reconnect. For all Races however even the slightest (fraction of a second) pause in pedaling causes the ‘You need to be paired for this event’ message to appear and once in the pairing screen I cannot pair.
iPad:
Same situation as for Windows detailed above except that when in a race it does allow me to pair from the pairing screen after the warning message has popped up. However this still makes it impossible to take part in a race."
He has followed instructions given by customer support to know avail including a full new install of zwift but that makes no difference.
Have you seen others with his setup that have this problem?
Any info you could provide would be much appreciated. Thanks!
After the introduction of the new pairing system, I have experienced my trainer going nuts with the resistance control maybe half a dozen times (never had anything like this in the years before, haven’t tested with other apps yet).
The first time was in the Innsbruck ZRL race where the resistance was stuck at max the top of the last Leg Snapper (I was barely able to turn the cranks on the descent), the most recent time in yesterday’s NYC ZRL rerun somewhere on the flats, the resistance was stuck at min instead so I was spinning out my top gear at 200 W. Both of these went back to normal after a minute or two.
About a week ago this also happened in free ride (this time stuck at something approximating flat ground) so I was able to experiment a bit. Tried first unpairing and re-pairing controllable, no change. Then tried rebooting the trainer via the power plug, also no change.
Equipment: reasonably capable gaming PC, Kickr V5 connected via bluetooth.
