Crashing on login
Running Zwift sandboxed under Win 10.
Got updates yesterday on the unsandboxed version, so I wiped the sandboxed version and recreated it to pick up the updates.
Tested both versions at that time and everything worked fine.
A few hours later (18:00 or so EST), the sandboxed version hangs immediately after the “Login successful” message appears.
I have attempted various combinations of deletes, restarts, reloads and system updates and cannot get the sandboxed version to work, even if the unsandboxed version is not running.
The unsandboxed version continues to work fine and I can log in with my account on that version without trouble. (Usually, that’s my wife’s version…)
Any ideas?
The sandbox is exactly as set up in the Random Neural Misfires description of running multiple instances of Zwift found here: HOWTO: Run multiple Zwift sessions on the same PC (Windows only) | random neuron misfires
Thanks!
This response is way after the fact. Did you (in Sandboxie) end all programs and delete contents in the Zwift sandbox before each try? I have found this helps a lot.
Did you resolve this? I’ve just attempted to use Zwift with Sandboxie after not using it for quite some time, and the same thing is happening for me
