I had a crash to the desktop in Watopia - Big Flat 8.
It happens twice so I think its reproducable. I noticed that it happen after reaching the ceckpoint 183 of 276 from this route.
Here are my logs from today:
[9:15:34] [ANT] BLE: Tacx set road texture 0 (time=2739061)
[9:15:36] [INFO] Auxiliary Controller attempting to connect to phone at: 192.168.178.55:21588 (secure)
[9:15:38] [INFO] Auxiliary Controller failed to connect to socket: ‘Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.’ (10061)
[9:15:39] [ANT] BLE: Tacx set road texture 0 (time=2744078)
[9:15:39] [Route] Hit checkpoint 183 out of 276 on route: " Big Flat 8"
[9:15:39] FPS 59.64, -64654, 12924, -8680
[9:15:40] [Garage Last Selected] Default Accessory assigned. Player Profile Shoes ID 0
[9:15:42] ASSERT: “!m_pVerts”, file=D:\git\zwift-game-client\Projects\ZwiftApp\CODE\UI\UI_Map3DBase.cpp, line=3072
[9:15:42] ERROR: ZwiftApp Crashed
[9:15:43] ERROR: ZwiftApp Crashed
And from 2 days ago:
[15:46:55] [Garage Last Selected] Default Accessory assigned. Player Profile Shoes ID 0
[15:46:56] [INFO] Auxiliary Controller attempting to connect to phone at: 192.168.XXX.XX:XXXXX (secure)
[15:46:57] [Route] Hit checkpoint 183 out of 276 on route: " Big Flat 8"
[15:46:59] [INFO] Auxiliary Controller failed to connect to socket: ‘Es konnte keine Verbindung hergestellt werden, da der Zielcomputer die Verbindung verweigerte.’ (10061)
[15:46:59] [Garage Last Selected] Default Accessory assigned. Player Profile Jersey ID 0
[15:46:59] [Garage Last Selected] Default Accessory assigned. Player Profile Shoes ID 0
[15:46:59] FPS 56.50, -64140, 12985, -7764
[15:46:59] [ANT] BLE: Tacx set road texture 0 (time=1910129973)
[15:47:00] ASSERT: “!m_pVerts”, file=D:\git\zwift-game-client\Projects\ZwiftApp\CODE\UI\UI_Map3DBase.cpp, line=3072
[15:47:00] ERROR: ZwiftApp Crashed
[15:47:01] [Garage Last Selected] Default Accessory assigned. Player Profile Shoes ID 0
[15:47:01] ERROR: ZwiftApp Crashed
Its the same ASSERT in both cases and it happens after passing checkpoint 183…
What can I do? I’m not sure if the route works before I have never rode it before.
Zwift version:1.1.13
App Launcher version:1.78.0(136426)
Windows 11 Pro Desktop PC Version 10.0.22631
Intel CPU i3 12100F
16GB RAM
NVIDIA GeForce GTX 1070
-Driver Version 561.09
Very fresh installed PC-System for Zwift only.
I havent had any issues before the last update of Zwift on Saturday.
