See attached picture -
Have had the Zwift Ride since September and done roughly 1000km on it so far.
Ordered the adjustable crank arms last week and in anticipation of them arriving today according to FedEx (that you should never trust, really), I figured I’d remove the original crank arms meanwhile.
I grabbed my trusty tools and set at it.
Something that immediately got me wondering was that the crank bolts where barely tight (I know I tightened them when the Ride arrived, and have done so once more, both times with a torque wrench set to 45nm), but none of the crank arms were loose and they were properly on there, as I noticed when using the crank puller.
Just as I got the drive side crank arm off of the Ride, I checked on FedEx who had updated the delivery date to monday instead of today as was planned and communicated…
“Oh well, no 165mm workout goodness today then.”, I figured and put the crank arm back on (after cleaning and lubricating all threads and friction surfaces).
As I was tightening the drive side bolt with the torque wrench, I could still wiggle the crank arm (not by much, but still some movement). I tightened slightly more by hand, but there was still movement.
I checked and compared the drive and non-drive side and just then noticed that the drive side crank was way more (about 2mm perhaps) outboard than the non-drive side crank.
I took the drive side bolt out again and just then noticed that the threaded “insert” inside the square taper was way out past the square. This meant I was tightening the bolt against that instead of pushing the crank arm onto the taper.
So far, I have tried (gently, I might add!) tapping on the “insert” with a hammer (cushioned with some wood), but it won’t budge. I have also tried grabbing onto it with a wrench (with some cushioning there aswell) to try and rotate it, but same result - No budging.
In all my years tinkering with all sorts of bike I haven’t seen this happen - Not sure if it’s a Zwift Ride-specific design or if I’ve just had the good fortune to not run into something like this before.
So now I ask all of you; What do? This is my only exercise option at the moment and I would hate to lose a bunch of days/weeks to returns/exchanges or getting in line at a bike shop.
