I just had this? (or a similar?) issue for my latest activity. Did two rides in a row, the first one did not have the issue, the second one did. In the companion app it shows “activity details could not be loaded” and the activity did not upload to strava.
First activity: 2245135365948112912 (everything as expected)
Second activity: 2245145331077546032 (details could not be loaded in companion, not uploaded to strava)
I tried restarting the app on my laptop, nothing helps. At the time of saving I had uninterrupted internet connection. I need to fix this activity ASAP
You should contact support. If an activity does not save properly, there is often no way to fix that, but you can grab the fit file stored on the laptop and try uploading it to other third party services like Strava. If the fit file on disk is corrupted then you might be able to fix it using Fit File Tools, but that doesn’t always work - it depends on what’s in it.
I did contact the Support, they were not able to recover the activity, nor fit file, it is pretty ridiculous you pay 20 euros per month, buy a dedicated bike from zwift for over a thousand, and still don’t have any certainty your activity will be correctly saved…
I don’t know the reason why it didn’t save (could be a bug, could be a problem with your system, could have been a momentary network problem) but you should grab the fit file from your system and upload it to some service like Strava, Garmin Connect, intervals.icu, anything like that you have set up. That will show you whether the data is good or if the problem happened before the game tried to upload it. If the file is trash then a successful upload would still look like what you are seeing.
I experienced this issue as well; it seems the activity summary was sent to Zwift, but the FIT file was not. Furthermore, the FIT file was not saved in AppData\Local\Zwift\Activities. I don’t mind losing the activity itself, but I am reporting this because I believe there might be a bug following the game_1_123_fit_file_hardening feature (I never had this problem before).
I noticed the following in the log for the unsaved FIT file: INFO LEVEL: [SaveActivityService] OnTerminalState: 2 in prev activities
And in the logs for activities where the FIT file was saved: INFO LEVEL: [SaveActivityService] OnTerminalState: 1 in prev activities
I had the same thing happen last night. It worked in the morning, but the evening ride did not save properly. Both Companion and feed on the web show the activity with basic details such as distance and elevation, but when pressing to go into the details view there is nothing there; no map, no HR data, nothing.
The first one only contains ~16 minutes, then there’s a ~1 minute gap to the inProgressActivity.fit file and approximately a 2 minute gap to the start of logging in the “18-47” file.
My HRM had a connection failure sometime during the ride, but I don’t remember when.
Reached out to Zwift support last night and they said HRM disconnected so the FIT file got corrupted. Not sure why that would corrupt the file, people have HRM disconnections all the time. Any way, I quickly started the HRM again after the connection failure, and everything looked to be normal in-game for the last hour of my ride (or however long it was after the disconnect).
Only found later that nothing had been synced to Garmin, Strava, Intervals.
@PH8 Sorry about the lost ride. One thing that might help with the three FIT files you found: I build a free tool called The Split at https: <_slash_slash_> thesplit <_dot_> fit .
Its Concatenate tool joins recordings made one after the other into a single activity file, which is exactly your situation.
It accepts FIT, TCX and GPX files (up to 15MB), and a gap between the files is fine; only an overlap of more than about 20 seconds is refused. You join two files first, then join the result with the third.
The result is one activity you can upload to Strava, Garmin Connect or intervals.icu. This guide walks through it: https :// thesplit . fit / articles / merge-two-garmin-activities
If one of the files is cut off or damaged, the reader usually still recovers the records up to where it stops. I’ve only tried this on my files, not broken Zwift output, so I can’t promise it rescues every damaged file.
Check the totals on the joined file before relying on it. The Help page covers the other tools: https :// thesplit . fit / help
Ps. Files are only held in memory while you work on them and discarded after about 30 minutes of inactivity.
PPS. This can’t help anyone here whose FIT file was never saved at all, which sounds like what @francis_franklin and @GlennVL describe. For them it’s a support case for Zwift, as @Paul_Southworth says.
unfortunately, there is a third scenerio, for me the file was not saved at all, nor the support was able to help and recover it, they didn’t seem to care. It was just a 1h zone 2 ride, but imagine somebody is racing or trying to qualify for zwift academy and their session doesn’t save, I think this shouldn’t be acceptable.
That’s the PPS scenario that Stefano mentioned, but Zwift support can’t recover data that doesn’t exist. It’s just gone. The purpose of contacting support is to apply heat to their work to fix the bug. If there’s no data then there’s nothing for support to do other than pressure engineering.
Zwift Support got back to me very fast. Their answer is:
There is a known bug after last update, that can damage the activity files on certain iOS-devices. They are working on a solution. Im using an iPad, btw.
I could recovery the fit file using iTunes (suggestion from the support). Didnt have to use a repair-tool.
@Jakob_Tosik in looking at all of the Zwifters reporting FIT file issues in this thread so far we were able to root cause your session to a FIT file writing failure due to “No space left on device”, which occurred 6 times during the activity you linked. Could you please direct message me with details on how much storage you have available on your Mac, and if you have any cloud syncing services (e.g., Dropbox, Google Drive, OneDrive, etc) that could be causing write issues to your Documents > Zwift folder?
A) is there any disclaimer or note informing the users that the activity files are stored locally and for their correct processing there must be space available on disc storage? I was not able to find such information. Answering your question, yes i indeed had low storage these last few days
B) I contacted the support and these details were not shared with me, which is a little bit concerning given that I could record next activities without knowing the storage is the culprit have I not freed it by accident
