Core 2 no wifi solution?
Does anyone have a solution as to why the kicker core two no longer connects to the zwift app by Wi-Fi? The only available option that shows on the pairing screen is Bluetooth. The trainer is definitely online and connected to the same network. This is verified through the Wahoo app as well as the Zwift Companion app under “equipment”.
My KickR Core2 is connected to my PC via ANT+………….no issues
And no virtual shifting, too.
Yep, went for a cassette, less to go wrong
Just spent 3 hours trying to connect new Kickr core 2 to ipad through wifi for a friend, gave up in the end and connected using bluetooth in 30 seconds, is this a known problem?
Did you download the Wahoo app and connect the trainer to the Wi-Fi through that before switching over to the Zwift app?
Yes and it was showing as connected to the wifi in the wahoo app.
Hello, I’ve encountered the same issue. For me it was on macOS. Reinstalling the app and giving it local network permissions fixed it.
This is common issue on Mac after some OS updates.
