I have 2 Wahoo Kickers attached to my stationary bike that track my speed and cadence. My question is at some points during my Zwift ride my avatar only goes 2 mph, then on other points during my ride he goes 20+ mph even though my power or RPMs don’t increase. I’ve done this on a flat course, and a hill course and it doesn’t look to matter. How do I keep him at a constant speed on the game? Any advice would be helpful, as it’s annoying to only go 2 mph for 30+ minutes.
Zwift take the watts being broadcast by the trainer, the weight entered, height entered, in-game bike used, in-game drafting (Tri and TT bikes get no drafting boost), in-game wheel set, in-game road surface, and in-game virtual elevation changes your in-game speed is determined.
Those are not Kickrs, so here is a different post on speed within Zwift:
For virtual power like yours:
Zwift takes the wheel speed broadcast by your speed sensor and the power curve of the trainer you select on the Pairing Screen and converts that to virtual watts. With those watts, the weight entered, height entered, in-game bike used, in-game drafting (Tri and TT bikes get no drafting boost), in-game wheel set, in-game road surface, and in-game virtual elevation changes your in-game speed is determined.
Thanks for the reply. I understand that. What I don’t understand is that Zwift will keep my at 2 mph no matter the wattage. Then 1/2 way through the ride it will randomly increase to 20 mph with the same wattage and rpms, and then it will decrease back to 2 mph. I just want a constant speed.
The only way you can have somewhat constant speed within Zwift is to ride Tempus Fugit, but your speed will change slightly since there is some small incline/declines.
