We upgraded both our IPAD rigs yesterday and today we are unable to ‘activate’ the Resistance component of the App. I tried both wifi and bluetooth connectivity on both rigs (unplugging the other trainer etc while doing so). I shut down and restarted both ipads as well.
Note1: In all cases the Resistances shows as successfully connected but there is no effect of changing the gears. Be in a group event or hill climb etc…
Note2: All other metrics are working fine, cadence, heartbeat, speed etc…
Note3: I did also try deleting the app altogether from the ipad, and run a fresh version. Results are the same as above.
Please advise.
Which trainers do you own?
Have you filed a support case so they can review your logs?
No, butsending an email to support now. Since i deleted the app on one of our trainers IPAD, not sure if there will be logs. As to the type of trainers both are kickerCoreV2.
Cheers
Alex
Based on your earlier comments, are you also using virtual shifting (Zwift Cog/Click, or otherwise)? If so, are you seeing your current gear selection in the window in the upper left corner?
Hi Nigel, both bikes have Zwift Cogs setup. KickerCoreV2.
On the advice of support they recommended trying everything WAHOO first.
The last thing I just tried was a manual spindown, very challenging to find how to do that on the V2 since its mostly been automated in the calibration.
HOWEVER< SUCCESS. After the manual calibration one of the bikes seems to be working.
Will do the same on the next bike and report here.
Happy to report, the manual calibration on bike #2, for the kickercore V2, also did the trick.
The gears and resistance seem to be working fine now.
I wonder if there is some sort of explanation. Perhaps a coincidence with software change or perhaps a broken connection between zwift and the trainer wrt to resistance…
