Connection issues with Polar watches
For a few days, I have been having issues with the connection between my Polar watches (Pacer pro and Ignite 3) and Zwift. This both on PC and Android. I have been using these watches as a heart rate sensor when using Zwift with no issues for a year. The connection has usually been with my trainer, Wahoo Kickr Core 2, as a bridge, so the primary connection is between the watch and the trainer and then to Zwift. Sometimes I have used a direct connection between the watch and Zwift when this pops up first in the list, also with no issues.
A few days ago, I could not connect my watch to Zwift. At first, after activating the “share pulse with other units” in the pre workout screen on my watch, it would not even appear in the device list. After a few tries it appeared but Zwift was unable to connect with it. When I clicked the device the box got blue for a second but then it dropped the connection. Sometimes it said “connected” in Zwift but the watch said the connection failed. After a while it could connect but the heart rate shown was “0”, both in Zwift and on the watch. After a while I realized that the watch sometimes made a second, separate, connection with my trainer (as a power sensor I guess?). A blue bike icon would pop up in the pre workout screen on my watch, and the moment this happened the pulse would stop showing on the watch as well (the light diodes were still active). I then manually unpaired the trainer on the watch in the settings menu, then tried again and now the heart rate was showing. I started the workout and everything worked as usual, but after a minute the heart rate froze at the current value and when I looked at my watch the heart rate was frozen there as well. The blue bike icon was active again on my watch screen when this happened. So the watch and trainer had automatically paired during the workout. After this it was back to Zwift either not finding the watch in the device list or it being there but unable to connect with it. No matter if the connection between my watch and the trainer was active or not.
I tried with different settings on “background pairing” in Zwift and unchecked and checked the new consent button there. I tried with “bridging” both on and off in the Wahoo app (interestingly enough this setting does not seem to matter, with it off it still connects and bridge my Zwift Ride controllers). But the same issue persist no matter what I try.
So as this happened after the Zwift update and the issue at first seemed to be that Zwift could not connect to the watch I thought Zwift was to blame. But then seeing the other connection between my watch and the trainer maybe it’s a Wahoo issue as well? That the trainer more aggressively looks for devices to pair with? And that this somehow messes with the ability of the watch to connect with Zwift?
