Hi Dan, I follow your update for TDF Data Bridge since 2020 and I hope you will can do some thinks for the TDF 1.0.
Regards,
Jean-Michel
Dan, I have TDFDB 4 full version working with Zwift but the incline it sets the bike to is approximately 30% of what Zwift is showing. Any way to adjust?
Hi Emma! Unfortunatelly this model is not compatible with the program
Hi David,
Please adjust Trainer Difficulty on Zwift Settings. That is what is causing the different readings. If you set it to 100% then positive incline will have a 1-to-1 relation. Remember that regardless of this setting, negative incline will rarely match, as it is always broadcasted from origin as a fraction of the incline shown on the simulation screen.
Hope this helps,
Dan
Hi Dan,
I’ve been using mu Taxc Neo, currently away visiting parents ( another country ) and my father has a Proform Model number PFEVEX71316.0
It is actually very quite and would be great I could make this work, probably for about 6 months then change back to my NEO.
Thank you
Stephen
Hi Stephen. Unfortunatelly that model is not compatible yet.
Best,
Dan
Dan:
Is there any chance you are working on ERG support for the old 2012 Tour De France bikes? I love that the data bridge works and lets me ride in Zwift and controls incline. There are some training plans that would work best with ERG mode.
Thanks!
Dave Schulz Full Version owner
Good evening can I ask if the pro form TDF CBC bike is it compatible with the app
Model number PFEX39420-INT.0
The TDFDB software bridge is not compatible with the CBC TDF bike that I know of. You could use the bike on Zwift by attaching speed and cadence sensors but Shoft of adding a power meter I don’t know that there is an accurate resistance solution out there with Zwift.
Hi Morten, the TDF1 is compatible. TDF1.0 is not.
Unfortunately the CBC TDF is not compatible
Hi David. Thank you! Unfortunately I could not make the ERG mode work on that bike while I had it. So far the only two models that support ERG Mode are TDF4 / TDF5
I wonder if @Roberto_Viola has encountered this hardware before. He makes an app that helps connect unusual trainers to Zwift (qzfitness.com)
hi! yes i can do the erg mode with qz! open a github ticket about this!
Hi Dan almost got it runnung here, what is happening with this window, in your program i get cadence & watt measures, but it comes up with this error
Hey Morten! That is the USB driver or the ANT+ adapter being picked up by another program. I’ll send you instructions to your email.
Cheers!
I have the “Proform Tour de France CLC Bike Indoor” - I’m not sure what version that refers to.
I presume it’s quite a few versions back as it only has a small display screen to show speed and time.
It connects to iFit via Bluetooth to a mobile phone or tablet which you can place on the centre support frame in the middle of the handlebars.
Is this bike supported by your script? If not, is there anything I can do to provide support to get it to work with Zwift?
