Hello! Can I use Wahoo sensors via bluetooth? Or exclusively via ANT+?
Thanks!
Thanks!
Wahoo sensors use both ANT+ and Bluetooth, but connecting them via bluetooth means going via your phone which is a hassle.
Anyway I use the phone or tablet… It’s more convenient for me through bluetooth than ANT+. So, if I connect the sensors to mobile phone and the application from mobile will synchronise with laptop, will read the data? Thank you!
You need to pair the sensors using the Zwift application, not directly with the phone, but you are essentially correct.
