Running the latest version of Companion on iOS. The durations for some routes that are a whole number of hours plus zero minutes are appearing as “2 m” instead of “2 hr” – perhaps the coding is set to give a number of minutes that is zero and it’s dropping the correct unit for the number of hours. I’m seeing this for any route that estimates it’ll take me some whole number of hours on the nose. It shows the correct duration when there are some number of minutes to add to the total. I can send a screenshot if necessary but I suspect this will be an easy thing to spot, despite every rider’s duration estimate being different for each route.
