I am using zwift and appletv. Not had any connectivity issues with the companion app with zwift before but now the companion app won’t recognise i’m riding so i of course can’t use this app or the chat. I have made sure both are connected to the same wifi. Uninstalled and reinstalled both the zwift app and also the companion app but still finding the same issue.
As a test i did load up the game but didn’t connect my trainer and the companion app did work. Has anyone else experienced this and have any solutions?
If that is repeatable it would be really weird. I mean if it works when the trainer isn’t paired I can’t think of a reason why it would stop working when the trainer is paired.
What happens if you start with the trainer unpaired, Companion working, then you pair the trainer? Does it disconnect Companion from the game?
Can you describe all the network equipment in your WiFi environment? Is there a single WiFi router or is it more complicated than that?
It is a single router. Probably another point to make is when i tried without the trainer connected i was on a different connection (connection A - with trainer, apple tv and companion app - not working)
(Connection B - apple tv and companion app - working)
Would there be any reason why it would be something to do with the router, even though all devices are on the same connection?
Generally if there is a single router, and both devices are on the same WiFi network, and both devices are using the same WiFi frequency (2.4GHz or 5GHz) then you should be safe.
Rebooting the router is always one of the steps you should consider as well.
When WiFi networks are composed of multiple nodes such as with a mesh network, sometimes you can end up with the devices connected to diverse nodes and that can cause problems, but that won’t affect you. In my home network I have two nodes and I have to make sure my devices are both talking to the same one. In my network it actually does not matter if one is on 2.4GHz and one on 5GHz but with some network devices it can defeat Companion’s discovery process. The usual way to rule that out is to set up two different WiFi network names for 2.4GHz and 5GHz bands so you always know which one you’re on. Most WiFi systems allow that.
Thanks I will give this a try. How will i be able to check which node i am on both my phone and apple tv? Presume there is a settings option on the connection page?
You have only one node if I understood you correctly (just the one router and nothing else) so if you want to see if both devices are on the same band (2.4GHz vs 5GHz) the easiest way to check would be in the administrative interface for your WiFi router. Exactly what that looks like will depend on what the make and model of the router. Or if you configure the router to separate the two bands into two different network names, that would be another way to know that both devices are on the same band because you would select the same network name on both the Apple TV and the phone.
