Companion app default to map
Would like to review new performance info on Companion app but as soon as I open it it switches to the map (even though I am not riding? How to keep on performance page. Thx!!
If you run Companion on an Android device, you can return to the Companion home screen via the menu options. If you run it on an iPhone, you can’t because there is no menu option for it.
Thx! Left to Wonder what is the value of inaccessible tools?
are you sure you have ended your ride correctly and closed the app?
I don’t have an iOS device but on android it should only going to the map when you are actually active ingame
That’s it! Yes I ended the ride and put Mac to sleep without closing the app. Awakened and closed the app and I can see the performance page. Thx!!
The way to do this with iOS is to just turn off the WiFi. Not as slick as Android, apparently, but it works.
Yes :100: except almost no cellular coverage for me at home so it barely works
I think better to just shut down the zwift app on the Mac as suggested earlier. It worked. Though it requires reconnecting all devices each time I ride…or better yet ignoring the new performance features in favor of those already available on TrainerRoad. Perhaps best to stick to ones knitting??
