Some issues that i recently encountered:
In the companion app, when scheduling robo pacer rides, there are various of the recently added robo pacers missing (e.g. 1.2, 1.4, 2.0, 2.4 W/kg).
On the home screen of the companion app under “What’s new” the Climb of the Week is still missing. Since the Route of the Week shows up there, I think this one should be there as well, and I often would really like to just jump into the companion app and check what’s the current route and climb of the week.
It would be great if you could add the Climb or Ride of the Week in the Plan tab to your week. The same would also be great if you could check and add active climb portals in general within the app.
I rode the route “Sand and Sequoias” quite a lot recently and noticed that the climb profile preview around the Titans Grove KOM is always significantly off in regard of where you are on the route and where the marker on the preview is located. it often shows that I’m still on an ascend while I’m already on a descend and vice versa.
Less of a bug or missing feature, but a change that I think would be useful regarding robo pacers. Currently they are classified with riding a certain w/kg in regards to their weight. That’s not particular helpful (especially for beginners), when trying to assess what kind of effort you need to stay with the robo pacer. There is the issue with the weight difference between rider and the robo pacer and there is the influence of the bike frame and wheels you ride. I recently started upgrading a gravel bike and noticed that on tarmac roads I needed to choose robo pacers 0.4-0.5 w/kg lower to achieve the targeted w/kg that I intended to ride. Wouldn’t it be much more effective to judge what kind of effort you need for a particular robo pacer, if they just show the average wattage (incl. robo pacer pace changes on climbs and descends and avg. draft that the robo pacer received over the last full loop of the route) you need to ride based on your current setup, body weight and height? Zwift knows all the maths that goes on behind the scenes and should easily be able to calculate this. I think that would be a big improvement, since i notice that when riding with a particular robo pacer i always have a rather constant average watt value over multiple hours of riding with them (fluctuations over time within 2-3 Watts). If we would get that estimated value in advance, it would be very beneficial.
