It would be great if the climb profile that drops down when you’re on a climb stayed visible whilst you’re on that climb. I get that’s maybe tricky for some of the less defined ones, but when you’re on a designated KQOM, it would be great if it stayed visible. At the moment, it disappears once the gradient is below a certain threshold.
Yeah, I find it odd that the climb gradient disappears in the middle of a KOM segment as well, seems like they should at least be able to special case those.
It would also be great if it showed the upcoming gradient of the route you are on also.
On the London Flat TdZ route today, just after the subway tunnel heading towards Richmond Park, the gradient banner showed the gradient for Fox Hill.
We made the turn, it changed for about 10 seconds while continuing on a slight climb, but not the whole climb shown on the Mini Map. An then it changed again to show the longer elevation reflected on the Mini Map.
In a perfect world, it would have shown the entire climb when it first popped up, as shown on the Mini Map. Not 2 additional changes.
