Change the "Ride On" text to "Run On" for runners
When giving runners a Ride On the text in the companion app and else where still says Ride On. Change the text to be Run On for runners.
I’m torn by this. Obviously ā€œRide Onā€ makes no sense as a runner - but it’s also the trademark Zwift phrase. As Zwift expands though, that’ll need to change. Maybe a ā€œZwift Onā€ to cover every activity?
Running has been around long enough that the ā€˜Ride On’ acknowledgment should be replaced with something more appropriate. My suggestion would be to use ā€˜High Five’ instead, which I think is fairly universal. You could even re-purpose the floating hand that was used (I think) for St. Patrick’s Day.
It makes sense. There’s some more discussion from last year about this and other running-related aspects of Zwift here:
Reading this post from @Mike_McCarthy1, I wouldn’t be at all surprised if changing ā€œRide Onā€ is coming down the track.
