I can’t login to Zwift on Windows anymore. The friendly error I receive after cliking on " Let’s Go" buton during the startup is:
Failed to login. Check internet connection
In the Log file there is some more information:
[15:02:04] NETCLIENT:[ERROR] Curl error: [60] ‘Peer certificate cannot be authenticated with given CA certificates’ for: GET https://us-or-rly101.zwift.com/api/auth
[15:02:04] NETCLIENT:[ERROR] Error finding authorization server: [26] Peer certificate cannot be authenticated with given CA certificates
[15:02:04] Login error: Could not acquire access token because credentials are missing
Does your IT department have a SSL inspecting proxy in place? This can often cause certificate errors because the actual sites certificate is replaced by a proxy generate one.
As I am not fully in control of the Windows Firewall, I am using a workaround now. I am running Windows on the same laptop but installed on a external SSD drive now. As it is my own setup, it working fine!
