Just wondering if someone could advise what has caused me to very quickly move from C to B? Doesn’t seem to make sense from the below summaries - the first is mine being Cat B, the second is a friend (who produces a lot more power) who is only Cat C.
That does seem a bit odd. I can’t spot the reason for the difference but just adding another data point from a rider nearer to your power and weight than the other guy.
17 minute PR set in a short hill climb race and nothing else similar, but longer, to compare it to. In other words the values immediately beyond 17 minutes are not accurate reflections of capabilities, so 20 minute power will be guesstimated by CE as higher.
Thank you - at least it’s not me completely mis-understanding things.
Exactly as has been suggested, I put in a really hard effort over a short race - which has created these figures. Over longer distances I can’t sustain this power.
Does the short (5-8min) effort need to be over a defined segment? Ie KOM, Sprint etc, or can it be at any time? I’ll give it a try.
Category Enforcement will use the power you produce at any point in any of your rides on Zwift, so you don’t need to do a KOM etc. That said, if your 17min power is high enough you might still come out of it with a B cat rating.
