Can't connect Companion
Everything is up to date… Companion apparently recognizes that I’m riding, because it says it’s what I’m doing, but I can no longer get the map to come up…
any help appreciated
Please tell us about your set up. The most common thing that leads to this issue is the device on which you are running ZC not being on the same network as the device on which you are running Zwift.
Hi Nigel - actually, just came in here to make a note that turning Airplane mode on worked, for whatever reason. I’ve never had to do that before, and frankly would rather not have to do it in the future if possible…
Big fan BTW.
If turning Airplane mode on helped, then turning Wifi Assist off will also probably stop you needing Airplane mode.
