Cannot Pair With Kickr Trainer When Paired With Spider Power Meter
Why doesn’t my Kick trainer show up in the “Controllable” device list when I’ve paired the Power source to my spider power meter? When I ride in Zwift without pairing my Kickr the resistance does not change according to the current gradient. (I set a new 20 minute power PR as a result! So it is not all bad.)
You need to pair your trainer as power and controllable then change the power to the power meter.
Yeah, it is annoying but as Gerrie says to use a different power meter to the trainer you first have to pair the trainer as power source, then it’ll show up in controllable, then you can go back and pair your power meter.
you’ll have to do this every time unfortunately
Thanks. The order matters!
