Cannot find rides
Hi
On a free trial but struggling. Done a couple of rides and really hard ftp test. Cannot find them anywhere. Definitely saved them. Not on Zwift app, companion app or Zwift/feed.
Are rides saved externally on a server? Or just on device?
Have you got to use companion app to save rides done on Zwift app? At same time?
Any help appreciated. Hoping customer service can help before trial expires on 13th.
Like Zwift but ROUVY just works.
What is your Zwift setup? And on what device(s) are you running Zwift?
Hi
Wahoo roller
iPad
I did not have companion app
FTP test saved to Strava, just no sign of it anywhere on Zwift thanks
Just checked, all 3 Zwift rides uploaded to strava, cannot find anywhere on Zwift.
I can see people I follow rides on companion app but not mine under just me.
Ta
Guessing this is you?
make sure you are looking on the companion app, not in the game itself. Sounds like you can see other followers activities on the companion app so you must be in the right place. Could you have possibly set up 2 different accounts with different email addresses? There are a bunch of ā€œMike Hank’sā€ under find Zwifters when I look up your name.
Thanks will check that all same account ta
Give up, back to ROUVY.
Maybe I’ll try again later in year
Thanks for trying
@Mike_Rowe1 is correct, you have set up two accounts. When you go into Companion App I assume it is logging you in directly, no need to sign in or password? And you activity is blank.
Mike is also correct that to set up two accounts you must have used either a different email or a different password. [Edit - you can’t use the same email for different accounts]
When in Companion App you need to go into Settings (via More or … in bottom right of screen) and log out. Then when you go back in again it will ask you to sign in again and enter password. If you ever use different emails or passwords or add something to the end of an existing password you will need to keep logging out and in again trying various options.
You could also try the ā€˜forgotten password’ option and reset the password.
Thanks looks like sorted due to you guys. This account will disappear, I’ll be back under my other account thanks
Thanks sotted phew. Did not fancy doing the ftp again.
Ive delrted other accojnt ta
Hi @mike_hank welcome to Zwift forums and Zwift more generally.
Shuji at Zwift HQ here. Are you using the same email address to log in to the game as you’re using on this forum? If no - please write in to our Support Team using the email you’re using in game.
We appreciate you bringing to our attention on this public forum, but matters where your personal information needs to be shared are best handled offline. I’m going to lock this thread so we can assist you via email, thanks!
