Can i use Garmin 735xt (watch) on wrist heart rate with Zwift?
(Jason Nubeebuckus) #1
Hi.  I have a Tacx Flow T2240 Smart Turbo Trainer and a Garmin 735xt watch.
Zwift pairs the Tacx OK (power source, cadence, controllable trainer)
But i can’t seem to use the Heart rate monitor on the watch (even if i start an activity).  I guess it’s not broadcasting the heartrate via ANT+, and i need to buy a separate heart rate monitor to pair to Zwift?  (then manually import .FIT file to Garmin Connect)
(Bastiaan Gaillard [HIK - C]) #2
Must be possible. Maybe you’ll need a firmware upgrade. Check this post from DC Rainmaker:
https://www.dcrainmaker.com/2016/06/garmin-forerunner-735xt-in-depth-review.html
(Amy - ATC) #3
I just paired mine. Go into Settings, Heart Rate Monitor, Broadcast Heart Rate, set it to Auto if it is off. That did it for me. I also have the latest firmware, but that is supposed to be required only to broadcast while in an activity. Ride on.
(Jason Nubeebuckus) #4
Thanks Amy, worked great :slight_smile:
(Adrian Ng) #5
Sorry for the newbie question…but when you guys connected your 735xt is it on a computer??
I tried to broadcast my heart rate from my 735xt on my iPad…however it just keeps searching without finding my garmin :(
Any help would be appreciated.
Thanks :slight_smile:
(Amy - ATC) #6
Yes. I think the 735 may broadcast in ant+ so you would need an ant+ dongle for your iPad, I used to do this with the 920 and Mio Link before I got the 735. Now I just use my computer. It seems like there might be a link somewhere on the Strava equipment page for the dongle and I think it plugs into the charging port.
(F atty-Roo RO4H) #7
I have mine broadcasting the HR to Zwift thru Ant.  The BPM is picked up fine.  However, it seems to corrupt the firmware or USB drivers on the watch.
I reset the watch to factory defaults, load up all my profiles again, etc etc.  I then go and ride on Zwift with the HR being broadcasted.
I then connect the watch to my PC’s either Win7 or Win10 and the PC’s cannot find the watch.    The USB charging screen displays on the watch.  When I remove the watch from the cable, the charging screen remains and I have to do a hard reset.
I’ve had to do this 4 times now even though Garmin says its being I downloaded Garmin Express thru Google Chrome !!!
Garmin IT today said that it may be the Zwift app that is receiving the HR is, somehow, corrupting the watch.
I’ll raise a ticket with Zwift support
