I used to enjoy Zwift cycling before. And I could select the direction at crossroad by Zwift companion or Mouse.
But with Zwift running, I tried to select the direction at crossroad by Zwift companion or Mouse.
My avatar goes to just fixed course. Is it normal?
It works exactly the same as cycling so you should be able to select direction.
I have come across some instances where it won’t pop up an alternate route for example coming to a Y or T, if you just tap the screen(using my tablet) it will pop up the 2nd route to choose.
Thanks for that Jason,
If you get specifics let me know and I’ll test it.
