Some kind of warning if cadence goes below a threshold. A reminder to change gears. I have a sore knee. Perhaps a way to turn it off though at a certain hill incline as one might run out of gears
Cadence is already on the screen. Could you not just look at that for a reference?
If you’re recovering from injury and want to avoid stressing the joint, I recommend putting the Trainer Difficulty setting at zero so you can pedal steady on all terrain.
You can also use a cycling computer to set alerts for some metrics. For example:
https://www8.garmin.com/manuals/webhelp/edge520/EN-US/GUID-15AC749A-87FA-43B3-B443-22629A981BB3.html
You can also configure cadence alerts in Zwift workouts. That would be another way to manage the resistance changes on climbs as well.
I’ll check those out, thanks!
