Good day fellow Zwifters. I received a beautiful Neo Tacx indoor bike today and starting the installation process. The challenge I need some help with is the fact that the cable cord comes out in the rear (under the seat) whereas it needs to be plugged into the jack in the front (under the ventilation units on steering wheel)
The cable is way too short to even come close. Could this be a manufacturing error by any chance?
Taking a guess since I have only seen the bike and don’t own one…
But is that post/rail assembly w/the cable the same as the post/rail assembly used for the handlebars? If so, you should probably swap them. Then the cable would be of sufficient length.
