CA Climb Portal Map
Thankfully there are plenty of riders enjoying the 80’s graphics on the climb portal but when will the CA get an upgrade to show the map?
That would be nice, but I’d just be happy if the stars would return to numbers on the descent so you know how far down the hill you are.
Absolutely! That was another thought that I had.
I doubt this will happen any time soon, since it would require a different map each time the climb changes.
be nice to have some proper scenery instead of a load of coloured square floating about the place
I wonder if the map could change/update when you go through the portal. Instead of showing Watopia it “updates” and only shows the climb. It appears the line of riders is floating out on their own anyway.
