Braking disable
When braking is disabled, the steering is disabled to. Is these an error or ment to be that way ?.
It depends on the context. If you disable braking in Zwift settings, steering should still work. If you enter an event that has braking and steering disabled, you may not see messages about both of those things. In Zwift Games events, for example, it is intended that both are disabled.
Been thinking for a few minutes now but I can not come up with one reason to disable breaking only … Why would they do that ?
i turn breaking off because the play controllers are very tight to my levers and can get accidently pushed to breaking when changing gear
I can understand that. But why would an organizer disable only breaking I am baffled about.
I understand that in all Zwift Events Breaking and Steering is disabled. Is these correct, then i will need a message about that in the comments about the events.
Not all Zwift events, but all Zwift Games 2025 events
It is detailed in the Zwift Insider post about the series, but I don’t see it in the individual event descriptions.
