Hi there, this is a repeat issue from October 2022. There is no speed being registered for my Bowflex BXT116 connected to Zwift on iPad Air. I can see it’s connected but just no speed.
Please assist. Thanks
I have had the same issue for the past 2 days on trying to connect a Bowflex BXT326 to Zwift running on an iPad.
The 2022 issue I assume you are referring to was apparently caused by a bad firmware update from Bowflex. Have you already contacted them to see if they are aware of this issue? The firmware updates are processed silently and they don’t seem to publish firmware release notes or allow you to check if or when an update was installed, so I think only they could tell you if they did something that broke it.
@Steve_Fung_INC_ZLDR certain Bowflex treadmills were also impacted by the changes that caused resistance issues with some trainers over the past few days. As of this morning August 24th, functionality should be restored in both cases. Can you please confirm after closing and re-launching Zwift if you are still experiencing the same issue or if functionality has been restored?
Mine is working as well now, thanks!
