FWIW, the greyed out companion app option just seems to indicate whether the companion app is currently running and connected or not.
The app seems to detect and connect if you run it while zwift is already running so you don’t need to run it first.
Make sure the Companion app is running, otherwise that option is grayed out.
Same problem
Very frustrated…
I tried to delete prefs , No result
Does somebody knows already the good solution?
Thx
Similar issue.
Have you a fix ?
In my laptop windows 10 fix it.
Go to folder Documents / Zwift / prefs XML
Try opening up the prefs.xml file with Notepad.
Looking a line that says <PREFER_NATIVE_BLE>1</PREFER_NATIVE_BLE>
When you find that, change the 1 to a 0 and fix it.
This is the solution for me.
Found the file but how do you change the 1 to 0? Tried typing and no luck.
Re: <PREFER_NATIVE_BLE>1</PREFER_NATIVE_BLE>
This work for me (by changing 1 to a 0). ![]()
John, any notepad app/program will allow you to edit.
It turns out that my laptop which runs the Zwift app and my Android phone which runs the Zwift Companion were using two different WiFi networks (one 2.4 GHZ and one 5 GHZ). Forcing them to both use the same network fixed all of my issues. The Companion now pops into Game mode as soon as I select a workout or a ride.
I am using the latest versions of Companion and Zwift on Windows 10 and this problem persists. I have already made all possible possibilities. I believe it is an error that needs a FIX. I can use the app on Android to do the pedal, but not through Companion.
