This is a first for me, my hub has disconnected sporadically the past two rides and has never had this problem before. I recently got a new desktop so please advise if there’s any settings I should investigate. I’m concerned the hob is going to drop out during a race. I will attempt an ANT+ ride later today/tomorrow to see if the issue persists in a different protocol.
Relevant log:
[9:20:36] [BLE] Sending DEVICE - BLE DISCONNECT ERROR [ UUID: 244511008029508 ] Zwift Hub FB44
[9:20:36] INFO LEVEL: [ZwiftProtocol] Component on “Zwift Hub FB44” changed state from 3 to 0
[9:20:36] DEBUG LEVEL: [ZwiftHardware] Device Lost ID: 322693523
[9:20:36] Device List:
[9:20:36] ===========================================================================
[9:20:36] Cadence: Zwift Hub FB44 (0x133BE993) [BLE]
[9:20:36] Power: Zwift Hub FB44 (0x133BE993) [BLE]
[9:20:36] Shifter Input: Zwift Click E176 (0x1C56E790) [BLE]
[9:20:36] Heart Rate: Forerunner (0x14D4FF84) [BLE]
[9:20:36] Non-Selected: Zwift Hub FB44 (0x133BE993) [BLE]
[9:20:36] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:pacers (children=false)
[9:20:36] [ActionBarV2] ZCActionBar: UserAction has changed: teleport:friends (children=false)
[9:20:36] [INFO] UDP host 34.209.156.251:3024 (secure)
[9:20:36] [INFO] Connecting to UDP server with relay id -2109620990…
[9:20:38] [BLE] Failed to retrieve GATT Services
[9:20:38] [BLE] Sending DEVICE - BLE DISCONNECT ERROR [ UUID: 244511008029508 ] Zwift Hub FB44
[9:20:38] DEBUG LEVEL: [ZwiftHardware] Device Lost ID: 322693523
[9:20:39] FPS 164.84, -549890, 10515, -471588
[9:20:40] [INFO] UDP host 18.236.113.35:3024 (secure)
[9:20:40] [INFO] Connecting to UDP server with relay id -2109620990…
[9:20:40] [BLE] Failed to retrieve GATT Services
[9:20:40] DEBUG LEVEL: [ZwiftHardware] Device Lost ID: 322693523
[9:20:44] [Route] Hit checkpoint 31 out of 223 on route: " R.G.V."
[9:20:44] [BLE] “Zwift Hub FB44” firmware version: 5.2.2
[9:20:44] [ZwiftHardware] “Zwift Hub FB44” NECOD: 0
[9:20:44] “Zwift Hub FB44” hardware revision number: 1
[9:20:45] [NETWORK] DFU: ERROR: checking for dfu updates; no response
[9:20:45] [BLE] Sending DEVICE - BLE RECONNECT [ UUID: 244511008029508 ] Zwift Hub FB44
[9:20:45] INFO LEVEL: [ZwiftProtocol] Component on “Zwift Hub FB44” changed state from 0 to 1
[9:20:45] DEBUG LEVEL: [ZwiftHardware] Device Recovered ID: 322693523
[9:20:45] [BLE] Reconnected and selected “Zwift Hub FB44”.
[9:20:45] Device List:
[9:20:45] ===========================================================================
[9:20:45] Cadence: Zwift Hub FB44 (0x133BE993) [BLE]
[9:20:45] Controllable Trainer: Zwift Hub FB44 (0x133BE993) [BLE]
[9:20:45] Power: Zwift Hub FB44 (0x133BE993) [BLE]
[9:20:45] Shifter Input: Zwift Click E176 (0x1C56E790) [BLE]
[9:20:45] Heart Rate: Forerunner (0x14D4FF84) [BLE]
[9:20:45] INFO LEVEL: [ZwiftProtocol] Component on “Zwift Hub FB44” changed state from 1 to 2
[9:20:45] INFO LEVEL: [ZwiftProtocol] Component on “Zwift Hub FB44” changed state from 2 to 3
[9:20:45] INFO LEVEL: [ZwiftProtocol] Comms established with Zwift Hub FB44.
[9:20:45] ERROR LEVEL: [ZwiftProtocol] “Zwift Hub FB44” decoding msg type 42 failed: wrong wire type
[9:20:45] ERROR LEVEL: [ZwiftProtocol] “Zwift Hub FB44” decoding msg type 42 failed: missing required field
[9:20:46] ERROR LEVEL: [ZwiftProtocol] Zwift Hub FB44 Timeout for GET [object ID: 0] after 1 attempts
[9:20:46] ERROR LEVEL: [ZwiftProtocol] “Zwift Hub FB44” decoding msg type 42 failed: wrong wire type
[9:20:47] ERROR LEVEL: [ZwiftProtocol] Zwift Hub FB44 Timeout for GET [object ID: 0] after 2 attempts
[9:20:47] FPS 163.93, -551521, 10515, -477434
[9:20:48] ERROR LEVEL: [ZwiftProtocol] Zwift Hub FB44 ZP Sync queue didn’t receive response. {description: GET [object ID: 0], sendCount: 3}
