Bias Setting in Companion App
The Bias Setting is set at 100% what is this?
I assume you see this while doing a workout.
This is used when you feel stronger you can increase the bias and that will then increase your workout targets, you can do the same if you cant reach the targets then you can turn it down. I think you can adjust buy ± 10%
Thanks, I was wondering the same thing.
