Something has changed. After each ride, then logging out, then back in, Zwift auto defaults to the Zwift Carbon bike, which I never use. In order to get my preferred bike, the Scott Addict RC, I have to first pick a route, then go into my garage, where I’m allowed to change from the Carbon bike to the Scott. Anyone else having this problem? Thanks for the tips and advice.
Yes, I had this issue on Monday.
On logging in I was on the Zwift Carbon bike. I changed it before joining an event. While in the pens I changed it again to the Zwift Concept. However others on the ride confirmed I was still on the Zwift Carbon from their perspective.
I haven’t used Zwift since, so I don’t know if it’s persistent.
It’s a known issue and there is a workaround…
Should be fixed in 1.25.1 which may be this week (can’t confirm yet)
Thank you James for your quick response. Glad a fix is on the way. It’s an annoying bug. Regards.
Cheers Paul, I hadn’t noticed that.
