Atv bridge connection disconnect since last update 6th Jan
Hi, since last atv update the bridge connection is dropping and losing devices.Comp app on Android, was working fine prior to update. Have tested with 2 different WiFi networks.
Anyone experiencing similar?
No working fine for me
This is one of those things where if you ask if others are seeing it, some of them certainly are, but for a wide variety of reasons related to the network or device settings and and not the app itself. If you can share all the details about your network equipment that would be a good place to start.
The other easy thing you can do is put the phone in airplane mode and then enable WiFi, to rule out the possibility that the phone switched to cellular data for some reason.
