Arrow to show direction across topo map
(Ray Whitney I Got This) #1
Simple…there is no way to determine what direction you are going across the topo/elevation map at bottom of map display. As rider passes from route to route, they may be going left or right and back again.
(Aaron Zwanzig) #2
The triangle inside the circle representing your position along the route profile points in the direction you are headed.
(Johnathan Freter [DRAFT]) #3
That arrow/triangle is pretty small on my 14 inch laptop screen. It would be nice if the elevation map had a bigger option.
Also if your doing a race, or a preset course, it would be great if the elevation profile would show the correct course but that a different topic and i’m not here to hijack this.
(Pitch Blank) #4
Yes i like to see this in future to with a compelte customizable HUD.
The gradient thingy is not new. Vote here:
(Aaron Zwanzig) #5
Agreed. It’s small from 3 feet away on my 32" flat screen. I think that the triangle on the route profile points in the same direction as the triangle on the immediate grade indicator. I could be wrong, though. I don’t pay a lot of attention to it.
