AppleTV app looses connection with trainer Tacs Neo 2T. Sometimes it happenes in 15 minutes, sometimes just after start.
tvOS is updated to 15 version, app is also up to date.
I use ATV and a Neo 2 which has had no problems.
I suspect it’s more likely something interfering with the Bluetooth connection so first thing i’d try is turn off everything electrical near by. If you have paired the Neo with other phones or anything make sure their bluetooth is switched off as a first test.
but the distance is less than 1 meter, and if i ride through iphone app, it works without connection losses
Ok, will remove pairing with iphone
now i just can’t get ANY connection from app to Tacx:slightly_frowning_face:
Отправлено с iPhone
