1.When I want to start a training or free ride i can´t see any other zwift driver on my apple tv. When I log on to the ipad I can see other drivers. If no other drivers are shown the ride will not be saved.
2.In the training program my wattage is not adapted to the training. For example, if I have to pedal 80 watts for 5 minutes, it is possible to pedal 200 watts without increasing the resistance by the trainer (tacx flux 2) automaticily.
There is currently a bug in the Richmond course where you don’t see other riders if using appleTV, this bug is found and a fix is on it’s way in the next update, soon. You should be able to see other riders in the Watopia world.
I do have the same problem … did you find how to fix it ?
In the training program my wattage is not adapted to the training. For example, if I have to pedal 80 watts for 5 minutes, it is possible to pedal 200 watts without increasing the resistance by the trainer … I use wahoo kickR
maybe the same issue as you?
Ran a free ride today with a friend. Road to sky. Very few power until i reached the green portal just before the beginning of the climb to Huez.
After this portal and during the climb: all good.
I run Zwift on AppleTV. Tacx Neo 2T as home trainer.
