This is the issue I also experinced.
But disabling the voiceover function solved the issue for me thx
cool Martin - to be clear , i was pointing out to Zwift support to actually reproduce the issue
Can you explain, how did you disable the voiceover function?
Thank you for the great video, showing movement and response!
Thanks for helping Vincent. I have an Apple TV 3G, experiencing the same issues as those with the 4K.
New ATV user here, first time this morning. I am having the same problems, it is unpredictable which way the highlighted button will move when I swipe on the remote, sometimes nowhere at all, and it is very difficult in some cases to see which button is highlighted (i.e. the arrows to choose between TdZ and the calorie mission). Very hard to get from the ride choice down to the start ride as well. It took way too long to get my ride going this morning. Voiceover is already disabled. Sometimes swiping has no effect, sometimes a swipe will move the highlighted button over several spots. Remote works fine in all other apps on the ATV 4k.
Iād guess that Zwift is well aware of the problem, and the issue comes down to the re-use of a UI that was not designed to work on ATV. Zwift doesnāt currently have the time or manpower to create an entirely new interface for ATV, it is on the list of to-do, but there are too many other platform fires to put out at the moment. We are probably just going to have to wait it outā¦
Have been using ATV 4K for a week. I only purchased it to use with Zwift. Same remote issues. Itās nearly impossible to select a course to ride on, select gear, or select workouts. I was pretty excited to switch from using an iPad because ATV looks better buts itās so difficult to use that Iām beginning to regret shelling out the cash for a device Zwift claims to support but, from looking at this thread, has obviously done nothing substantive with for months.
Many issues here using ATV 4k, including all the remote issues mentioned above. Our big problem was the app would crash under the following conditions: BT connected milestone footpod, selected running, choose ātrainingā in the top menu to access the workout menu. Upon attempting to scroll from the top level to any of the workouts, the app would crash. I switched to ārideā, connected my Kickār, saved a short ride, disconnected the Kickār, reconnected the footpod on the run side and it started working. Time will tell if this actually made a difference, but so far so good.
As for the remote issues - as others have mentioned - the remote sucks with Zwift. So I downloaded the Apple TV Remote app from the Apple store to my iPhone 6s and the app works way better in Zwift than the supplied ATV remote.
Next Iād like to see a custom workout builder for the run side.
For what itās worth, my remote experience has improved a bit in the last monthā¦ Itās still not IDEAL, but itās much better than it was the last time I chimed in. Now it only takes 2 or 3 attempts to get it to respond to swiping between items and even sometimes works on the first try. Much better than the often 5 or more attempts it took the last time I spoke up.
Now if theyād just allow us to turn off the menu music like you can in other platformsā¦ Been waiting for that fix to come through since they announced it last yearā¦ I know the work-around is as simple as hitting mute or turning the volume down until youāre in the game for now, but itās frustrating that ATV is the only platform where this feature isnāt available yet. Perhaps it will come with the āGuest Worldā update when they finally roll that out for ATV?
After what felt like many frustrated hours trying to navigate the Apple TV remote, I decided to look on the forum to find many other users with the same issue!
I think we are sometimes very quick to complain and not so inclined to thank! I have to say that there has obviously been some work done on this issue as my experience over the last week or 2 has been almost perfect! Chapeau zwift for listening and responding so quickly! Thank you!!
You beat me to this. I used my ATV on Friday and Saturday for the first time in a while. I found the whole navigation fine. Moving between buttons was easy.
Thank you, and as said above we do not thank enough.
Ride On!
While the remote is finicky, it is not the horrible mess one might expect after reading this thread or others on this board. For every complaint, there are probably dozens, hundreds?? of people who have no issue. That is the nature of the internet. Those w/out issues do not go online to say āI have no issuesā This is not to discount those who are having problems. Like I said, on occasion I find it a bit finicky. But, the fact that it works fine for so many does make it hard from a developer standpoint to reproduce and/or fix.
^Hi,
Apple TV 4K 32GB same problem as you with the remote.
No need to repeat in more detail. Just another ATV4k/32 Gb here and using remote sucks. Otherwise, Iām very happy using Zwift on ATV.
Just a quit tip; product of my frustration over not being able to claim bikes Iāve earned! The remote wouldnāt move off the current frame. So, the tip, let the bike come to a complete halt, with riders foot on the ground, before attempting to select a new frame/bike. Worked the first try.
This helped me so much already! I was getting so frustrated but it seems the Apple remote doesnāt work the same with zwift as it does when navigating the home screen.
Still need to spend some time using it on zwift but I was actually able to select things I was trying to!! Life saver!!!
Andrew
When can we expect this issue to be fixed? This was first reported back in September 2018. I didnāt have any issues prior to then and have no issues using the Apple TV remote with any other applications. Seems to me it is an issue with whatever code changes were made to the Zwift app in September.
Quite frankly I donāt feel Zwift customers using Apple TV should have to wait nearly 6 months for a fix to this issue. This is even more of a problem since the recent update with world switching as it adds more complexity to the menu selection.
Just to throw some fuel onto the fireā¦
ā¦ I have absolutely no problems using the Apple TV remote on Apple TV 32 GB 4K in Zwift for riding or running, be it training plans, selecting training sessions (even from a list of many), changing settings, joining events, selecting kit, selecting screenshots before saving, saving, you name it, Iāve really no problems at all.
Iām experiencing difficulties in moving in the Workout and Pairing menu as well. Sometimes the focus is not moving at all no matter how many times I sweep my finger on the Apple TV pad. It is a bit difficult to exactly describe what the problem is, but Iām sure moving in the menus is not supposed to work like this. It is like the remote randomly works and sometimes not. I have the latest version of Zwift app on Apple TV 4k with the latest firmware.
I struggle sometimes, seems to be sporadic though. Sometimes Iām in & out, select everything I need easily. Other times thereās one false move and suddenly my FTP slider is going up and down, then I know Iām in trouble.
When it isnāt working well it feels like thereās no logic to which āframeā will be selecting by moving up/down/left/right.
Itās definitely (in my expert opinion ) the Zwift menu(s) format thatās the issue as if I go to rename a ride after Iām finished then suddenly I can navigate the on screen keyboard easily again.
