because I wint ta connect my new polar smartwatch on bluetooth, I have to connect zwift with ant+. I have 2 questions. Is a 5 meter usb cable ok or will it give data loss because of the length?
Is there any dfference between cheap ant+ dongles like Cyclplus and the pricey one from elite/tacx/wahoo?
What system are you using for Zwift? What is the reason that you need to use ANT+ in order to use your smartwatch?
I don’t think there is a difference, I use a cheap one and it’s worked great for many years. I have a 3 meter extension, however not a 5 meter. Not sure if that will make any difference?
I’d be leery of cheap ANT+ sticks - there are reports of off-brands being less reliable. You may get lucky … or not.
If you have one and it’s working, great.
If you’re trying to source one, find a used Garmin ANT+ dongle on eBay, or in a thrift store. They’re often bundled with original Vivofit 1 and Vivofit 2 bands. (I’ve found them for $7.00CAD locally)
I have an Anself dongle which has worked flawlessly from day one, and I can also vouch for one by Magene. Both are/were around £10 from Amazon. I see no reason to spend £40+ on a branded dongle considering it’s literally the same chipset inside. Much more important is your wireless environment.
I have had ananself dongle too which worked great and have had a few Magene sensors (heart rate, speed and cadence) and they all worked perfectly too haven’t tried their ANT+ dongles though.
I have a Polar Pacer Pro sport watch. The watch records my activities and training progress. I cannot import the data from zwift directly in the Polar platform. Therefore I want to record the data directly from the Elite Direto X.
If you can live with 3m that’s more likely to work, but many 5m cables will be fine for USB 2.0 if they’re not garbage quality. If you buy a decent one (preferable returnable) it’ll probably work out OK.
And the specs certainly don’t say anything about the cable being active.
Anyway, all the dongles are USB2 so a USB3 cable is just a waste of money, and 5 m should be fine with USB2. If you already have a 5 m cable, just get a basic dongle and try it out. (I think I have a 3 m extension with an unpowered hub at the far end, works just fine.)
