The current Advanced category for everyone above 725 ZRS really destroys any motivation to race for heavy sprinters.
I am almost 100kg and I win or am on the podium on a lot of flat to rolling races in the up to 725 category.
BUT as a heavy sprinter my FTP is only 3.2-3.5ish and I usually have the lowest Wpkg in the whole field of around 3.2-3.5ish, while the other riders are at 4.0+.
The wins of course push me up in ZRS. In the Advanced category however there are always riders that push at 5-6 Wpkg, which I can’t even hold on pan flat courses in the draft, because it requires FTP or around 4.0.
So in Advanced races I am practically always the very first to get dropped. However, since I am not very motivated to do a time trial afterwards and only do Z2 till the finish, my finishing score does not count towards my ZRS, because Zwift assumes I am sandbagging. On top of that is the declining performance during winter, making my FTP even lower but my ZRS is not decreased because my performance is too low.
So I am stuck to shitty Advanced category, although my FTP is probably almost cat C in the old system. Those A+ riders really destroy all the fun in Zwiftracing for those who are at the category border, especially for heavy sprinters.
Zwift should really introduce another category above 850 for those A+ riders.
Then someone at 860 is going to have the same problem as you now. Someone has to be at the bottom of the category. Until/unless Zwift introduces an autocat system where the field is split into equal-sized pens just as the race is about to start, I don’t see any way out of this.
The problem is that you can enter Advanced category with an FTP of like 3.5 and you have no chance at all to even stay in the draft, if the pacemaker has a like 50% to 100% higher FTP than you.
I am deep in the red, just to stay on, so I drop after a few mins because it makes no sense at all.
The difference in Power from entering to the highest in the field that are the pacemaker for the field is WAY too large.
In lower cats it is not possible that someone with twice your FTP, someone you cannot even follow in the draft, is allowed to take part in the race.
Advanced races have low enough numbers as it is.
Split it again and then literally nobody will be there to even race.
I understand the frustration; but an empty race is equally as pointless as an unfair race.
The reality is just that Zwift doesn’t have the numbers to support good racing across the board. There’s nothing that will fix this except killing off the competition and also being able to grow numbers which is just not going to happen.
Anyone willing to race in events with low numbers can just avoid ZRacing and do literally anything else, because there is exactly one racing series that uses the Advanced category.
Race something other than ZRacing then. Yes it can be harder to find good events but once you find a series you love you may never go back to a ZRace.
ECRO is using ZRS over the winter with A cat at 775+ but it’s mass start so even if you get dropped by everyone in your category you’ll still have someone in a lower cat to ride with/against
Is that partially the result of no one with ZRS below, say, 800 wanting to do the Advanced races though? With a score around the 725 cutoff for upper A, it’s not worthwhile racing in Advanced just to get immediately dropped by the strongest racers (not to mention the obvious cheaters). Plus there’s usually a couple of sign ups that just go walking pace, so if you put in any effort, your ZRS can still go up, leaving you stuck in a category that isn’t appropriate.
In the Rhino crits we capped ZRS at 800 for the A pen, and then had the A pen start with the B pen. So it differentiates those riders a bit better, but still, low numbers. For a “standard” community race (ie, not something like ECRO) honestly I do not know what would draw people away from ZRacing. Unless you invest in a novel platform to manage a series, or it’s in some way more different from ZRacing (eg, a chase race) I’m not sure there’s any point in offering community races anymore. Zwift ate the whole pie.
But that is exactly the problem, although this thought is correct at first view.
However, I am a heavy sprinter and already in the lower category (-725) always had the lowest average Wpkg although I made it to a lot of podiums or wins. For Advanced it is that low that I can’t even stay in the draft and afterwards have to do a 30min time trial for the race to even count for a decrease in ZRS.
There is no workaround for the bottom-of-category experience other than racing the whole thing from start to finish regardless of your position, or doing events that don’t use racing score, like club ladder, DRS, or various races that use the old category enforcement pace groups, etc. It looks like you are already exploring those options. You can still have a bottom-of-category experience in those events of course, but chances are low that they will exactly match the ZRS bottom-of-category experience you’re having now.
How is your FTP? If your could focus on longer intervals and drag that up it might help you to hang on to the draft, then when you are near the end you can hit them with a big sprint.
More work on the FTP would definitely help. That’s what much lighter riders (65kg) do at real world (on real bikes outside) higher level competition, and these . You really need that to hang on - hence when in the advanced category it’s so hard for him.
That will take a lot of work, but it’s not impossible. It comes down to do you want to do the work to make it happen?
No it wouldn’t. There are 80kg riders with over 400 watts for 1 hour. He needs a lot more raw power to be competitive in the advanced category. You need more power over longer durations to be able to keep with the competition and be there at the end. It’s no good having a huge sprint if you aren’t able to stick with the pack.
And that means a lot of structured training and a lot more riding. Not just some races here and there and some assorted rides elsewhere.
Dozens, worldwide? Surely you jest. Even just in my real world riding group there are some at that level.
Clearly doing as he is doing now won’t get him more competitive in this category and the current riding that I can see him doing isn’t enough. Needs to try more and see if he can bring that power up, any gains will help. Yes, it’s hard - but you have to try.
Instead of doing zone two until the finish, try doing some flat-out 5-10 minute efforts, depending on how long the race is. It’s a race, so even if you are dropped, burn those proverbial matches. Use it as more training so you get at least something like the expected TSS.
Hyperbolic. The real figure is likely in the thousands.
That’s people in peak physical condition and not going far below the continental pro level. It’s not realistic to suggest that someone can get there through training. It’s 99% genetics, and that’s to get there in their prime.
