Add icon to turn options at junction to indicate route direction
I ride with a steerer and many times whilst trying to complete a route I have not been paying attention when coming up to a junction and not seen which direction I need to take to continue on the route I have chosen, usually somewhere near the end of it, resulting in a lot of frustration and having to complete the route again.
It would be great to have some sort of indicator added to the direction options when coming to a juntion to indicate which direction I need to take to follow my chosen route.
When you have a steering device you don’t need to touch it to remain on the route. Staying on the route is the default option. Some steering devices will also offer you a Zwift setting called Intersection Controls. If you toggle that setting it will prevent you from accidentally steering off the route.
@Paul_Southworth Yep, the problem is that I use the steerer quite frequently in game, and if I happen to be steering whilst the options pop up then it will select a different option than what the route should take and I have no way of knowing which is the correct route to choose.
I have just found the Intersection Controls option, which I was not aware of, thank you!
