Like many others since 2015 still to date 2022 the issue/bug with synchronisation and data loss if you go from one device to another and forget to close one.
A simple solution and a fix that would be great if implemented into the software. Add a login to one device at a time, basically if you login on one device your are immediately logged out of the other thus eliminating this common issue since 2015. This is a common software solution/feature that is used in most other software programs.
Thats my input and i hope to get other people onboard to make this change happen.
Thank you
