Hi all,
Just been on Watopia after updating zwift on Apple TV and noticed my heart rate is way high,I don’t have any road feel and no resistance on any climbs any fixes would be appreciated
Have you checked to make sure that everything is paired with Zwift correctly, and that you are not in erg mode?
Yep everything’s paired and I’m not in erg mode it was working fine last night and I’ve never had any problems before tonight
I know you have stated that everything is paired but double check that your trainer is paired as an FE-C device. FE-C allows the trainer to be controlled by external software.
Sometimes after an update my trainer will pair without this.
Tried again tonight rode Richmond and the road feel worked then went on Watopia but still no road feel on the boards . Resistance seems to be ok as does the heart rate readings
