6/24 Update problem
(Nathan Guerra (Vision)) #1
After todays update zwift cannot run properly on my computer it seems.  I cannot get past the devices screen and it stall horribly.  Have never had a problem with Zwift before.  My computer is plenty to handle anything Zwift can throw at it, I run multiple games at a time at the highest graphic settig on tis computer without dropping FPS.  When “tabbing” between programs it stalls horribly and cannot seem to find Zwift initially when I tab to it.  Only after a few tries does teh cursor interact.  I restarted my computer and Zwift multiple times.
Specs:  WIN 7 Pro 64 bit
I7 5930k 16
Nvidia GTX 980
Found this at the bottom of the launcher log?  Maybe issue?
**[3:25:54 2015-06-25] Patcher: Kicking download of missing local files from server…
[3:25:54 2015-06-25] Patcher: Completed download of needed server files for update.
[3:25:54 2015-06-25] Patcher: Copying new and replacement files into place…
[3:25:54 2015-06-25] Patcher: Copying new/replacement files downloaded from previous session into place…
[3:25:54 2015-06-25] Patcher: ERROR #Z-5, FILE “Patcher.cpp”, LINE 346: Failed to Copy new/replacement files downloaded from previous session into place!
[3:25:54 2015-06-25] Patcher: Parsing local “Zwift_1.0.5451_manifest.xml”…
[3:25:54 2015-06-25] Patcher: Iterating “Zwift_1.0.5451_manifest.xml” to verify local files…
Patcher: ERROR: Local Manifest is missing or corrupt!
Also, getting this in teh regualr log
**3:26:26] NETWORK:error (4) sending player state
[3:26:26] NETWORK:error (4) sending player state
[3:26:26] FPS 34, 8803, 10196, -23009
[3:42:01] Giant dt in app. dt = 9.01
[3:42:01] NETWORK:error (4) sending player state
[3:42:04] ANT : Could not assign channel 0 to network 0
Thanks for any help!
(Jon Mayfield) #2
Hi Nathan. Kill Zwift and try unplugging and replugging the ANT dongle. Sometimes the ANT driver gets into a strange state on Windows.  Unplugging and replugging can reset it.
(Nathan Guerra (Vision)) #3
Good to go, I reinstalled and then did the ANT+ dongle removal since I read this after.  Not sure which was the fix, probably your suggestions.
Thanks.
