Route ideas and help please
As a Friend of the worlds biggest cycling podcast - The Cycling Podcast (TCP), I’m organising a group ride on Zwift for the podcast fans
I’m looking for something that’s up to 90 mins long and contains 12 hills (not mountains).
Probably quite a few options if you’re willing to do laps of a short circuit, but if that’s too boring then Zwift Games 2024 Epic is probably closest to requirements. Some of the hills would be more like bumps and 90 min would require a little over 3W/kg for a medium size rider
You can make a route like Deca Dash whatever distance you want by doing laps of The Classic (it just does the climb in reverse).
I did Deca Dash in 1:23 at 2.8W/kg (and plenty of draft). Twelve laps of The Classic in 90 minutes would be more than I could do, though you could end it at the top of the last KOM to shave off a little.
Dave,
See attached. I think if you finish it off with Javis island you would have the 12 hills. It won’t let me add waypoints in javis section. Attached is the Jpeg of the route.
