People have problem on pc after 1.85.2 patch cant use workout wats I set it to 150 watts, I can drive it at 300, it does not reflect 150
Hi @_Oguzhan
Shuji at Zwift HQ. I’m looking at your server logs, and it appears that you’re doing some troubleshooting with a PC and a Galaxy Note20 tablet using different methods to pair to your trainer.
Question for you: do you have more than one trainer? Or is it just one Elite trainer?
This is the first I’m seeing reports of a workout issue in 1.85.2. Where have you seen other people with similar symptoms?
I also see that you use a custom workout. Is it imported from Training Peaks, or is it one you created in Zwift directly? Would you please look over this article about Custom Workouts and verify that the workout file follows those guidelines?
